SIM CARD
Dewana
After ordering a mail-in SIM card a few hours ago I found out that an E-Sim could have been faster/ instant connection - is it possible to switch over to E-Sim now, if so, how ?
yeah
for those who can login, it is still good to login and get a reference number
@slusagm wrote:
@computergeek541 if you tried using the Chatbot, they will ask you if you can login My Account, you said no and they give you the same link to message support. Try it and you will know what I mean
and he won't be able to login My account because account not setup and can't receive 2FA
You're right.  It used to the chatbot would continue witht he ticketing system would prompt for the verfication quetsions.  I am very suprised by the chatbot's resposne because Public Mobile does not want customers to actually send private messages in this way.  It leaves the erroneous imporession to customers that using the chatbot to open tickets is optional when it isn't.
@slusagm wrote:
yes, you can switch but you need PM to help
at this time , you cannot use Chatbot to open ticket as you don't have a working service yet. So, message them using this link here
Even with the inability to log into Self Serve, customers still should still be using the chatbot to open tickets.  There is a specific option for that situation and the security verification systems are promped for during the ticketing process.
eddieO
@Dewana more than likely you should be able to switch if you contact the CS_agent quickly. You will need to open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
slusagm
