05-12-2023 11:33 AM
05-12-2023 11:38 AM
the error " is not a canadian number" is either because
If you are porting in from Koodo prepaid, you have to activate with a new number first. Once activation completed and you can make calls and recieve calls, then you will need to open ticket with PM support for a manual porting request.
if you are NOT porting in from Koodo prepaid but was re-attempting the activation a second time, you will have to open tickte with PM support and have them to clear up the earlier activation attemp
Please open ticket with them by direct message:
