09-26-2019 08:24 PM - edited 01-05-2022 07:17 AM
I activated my SIM card as the steps from GET STARTED, but it didn't finish. When I try to activated again from the GET STARTED, it said my SIM card number is invalid. I tried login with email and password which I activated, it didn't work. What can I do with my New SIM card? Thank you!
Joining Public
09-26-2019 08:32 PM
Many thanks. I will try again.
09-26-2019 08:31 PM
@Patrick2019 wrote:I activated my SIM card as the steps from GET STARTED, but it didn't finish. When I try to activated again from the GET STARTED, it said my SIM card number is invalid. I tried login with email and password which I activated, it didn't work. What can I do with my New SIM card? Thank you!
After checking if sim works and if they charged, wait 1 hour if you weren't. Try activating after that. When activation doesn't finish, it locks the sim card out temporarily.
09-26-2019 08:30 PM
@Patrick2019to add to what @GR If your card didn't get charged (or didn't get there to start) and the SIM card doesn't seem to work on the phone.. give it a rest for an hour or so.. so the system will unlock the SIM card serial number and try again.
09-26-2019 08:26 PM
@Patrick2019 you can try your sim card in your phone to see if it works, also can you check if your credit card was charged.
