SIM Adapter
zakhan78
Hi, Does public mobile provide sim adapter? So the same nano sim can be used in iphone and samsung phone.
thanks
zakhan78
SIM jacket is more useful in which if you buy nano sim, which can be use in apply ansame SIM can be used with Jacket to use in samsung mobile
@PowerLemons,
I use SIM adapters since many years and I can say that they are totally safe if you use your head.
chukdefatey
Sim adapter work just fine if they are good quality ones. However bad quality ones will work as well but in most cases I don't suggest putting into the phones where the sim card slot is embedded into the phone. I only recommend it for external sim slots.
PowerLemons
@zakhan78
It's not recommended to use a SIM card adapter, because it has the possibility to rip the pins out of a SIM card slot - mostly and especially with cheaper low-quality SIM card adapters. This can seriously damage the phone, and requires a solder specialist and a lot of money to repair.
There's probably little-to-no risk with a more expensive higher-quality SIM card adapter, like the Sadapter, but it's something to keep in mind.
Cyber
@zakhan78,
Public Mobile offer TRI-Punch SIM card who offer all size.
OR
You can purchase a kit of adapter on eBay for 0.99¢
