SEND YOUR PRIVATE MESSAGE TO: CS_Agent
Alp_Int
Hi, I bought a phone plan yesterday and set it up on my iPhone via esim.
Today i try logging into the app and it says I must choose a subscription plan, as if it does not know i am customer.
The issue is that I can receive the evergreen verification text code, but once logged into the app it says 'Please select a plan'. I don't want to pay for a second plan.
1 REPLY 1
@Alp_Int
The error indicates that the Eversafe login system is unable to locate your My Account from your email login.  But no worries, it is an easy fix for PM support, you will just need to engage them by direct message.  Please private message CS Agent at:
