Roaming for Spain
Mohman
I’m travelling to Spain today and I wanted to know where I could get a plan that I can get data for internet and calls back to Canada?
any ideas where I can find that?
2 REPLIES 2
@Mohman
If you and your parties have the WhatsApp. You can call and text back to Canada for free when you are connected to wifi or local SIM with data.
Chalupa_Batman
Public Mobile only works in Canada, the United States and Mexico. There is no roaming outside these three countries.
If I may make a suggestion though that might be worth looking into. You can download an app like TextNow, pick a local number to where you live now. Then, look at getting a eSIM from Airalo. Here's the link.
https://www.airalo.com/
Side note, download the TextNow app with your local number ASAP before you leave the country.
