Roaming add ons not activated
ltalis
Purchased add-ons for roaming data and phone calls but nothing works. Please help!
8 REPLIES 8
@ltalis good to hear about that
Rockdaddy22
Thanks for the update 🙂
ltalis
Thanks everyone. All is functional. Love this community!
Mary_M
Retraité / Retired
Retraité / Retired
Hey @Italis,
I've just checked on your account and the roaming add-on is active. Make sure that you've enabled roaming on your phone and that you're connected to AT&T !
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
jaswest2754
First thing did you follow the two steps to adding it. It asks for payment the first time then you gotta go back and add it again after payment has gone through. You can also check this easily by going to plans and add-ons and seeing if it is in your add-on section. If you did this and the add-one were there then did you turn on data roaming when you crossed the border and manually select a carrier such as AT&T or T-Mobile (I would chose AT&T they have better coverage)
will13am
If all else fails, send a private message to a moderator.  They should be able to help fix whatever is the problem.
@ltalis
did the add on appear on the self serve account by anychance. If it is it should have kicked in once you hit US towers.
Also did you manuelly select AT&T roaming in your phone?
ltalis
I'm in the US btw
