Roam data doesn't work. can i get refund
xiaowei_zhai333
I travelled to alaska and bought 10 days roam data. But it didn't work here. can I get refund.
Thank you for the tips.
8 REPLIES 8
xiaowei_zhai333
Thank you so much. I just did it.  Now waiting for the Agent's reply. It will take about a day.
xiaowei_zhai333
Thank you for your links. I did it by following your suggestions. Very helpful.
@dust2dust Alaska is a funny States.. not sure why it is so hard to connect this year.  🙂
@halofreak79 wrote:
Did you make sure the package was compatible with Alaska? A lot of things exclude Alaska and Hawaii
There's no such exclusion for Public Mobile U.S. roaming add-ons.
halofreak79
@softech- Alaska. Please read. See @Timer : You're not the only one I might notice something with.
@xiaowei_zhai333
 are you still in US now?  Which city and state?  Try to manually connect to T-Mobil or AT&T and see if it works, don't rely on Automatic network selection .  But if you have voice component for your roaming, connect only to T-MOBILE
If it still fails or you are back in Canada already, then yes, open ticket wirh PM support and request compensation:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
Timer
@xiaowei_zhai333
contact to support team by private message CS_Agent  to remove it and get refund.
