3 hours ago
- last edited
2 hours ago
computergeek541
2 hours ago
@Kriti01 wrote:Where can i view my rewards. The new upgrades system is confusing
There isn't any way to view the amount of rewards that you can expect to get in the future. The current system only shows the amount of points that you have earned in the past. When it comes to the number of referrals, there is a graph, but only shows the number of new referrals (and not your total number of referrals).
2 hours ago
yes, you can only redeem bill credit at multiple of 15 points.
2 hours ago
For bill credit yes😔
Add-ons starts at 5 points.
2 hours ago
Is it a min of 15 points that we need to accumulate to redeem?
2 hours ago - last edited 2 hours ago
@Kriti01 you can view here.
https://myrewards.publicmobile.ca/en/on/catalogue
You can scroll through the lists of items to see what you want to redeem.
15 points is $15 off your next bill.
From the main page it usually have error and doesn't work.
