Rewards
Options
06-19-2023 10:15 PM
If I change my plan to a different Public Mobile plan do my rewards stay the same or do I go back down to $0?
Labels:
Rewards
2 REPLIES 2
Options
06-19-2023 10:29 PM
Thanks!
Options
06-19-2023 10:17 PM - edited 06-19-2023 10:18 PM
@terryotots You get to keep your old rewards I can confirm I just switched myself and kept old rewards .check it out
Add there tied to your account. Not your plan
