09-08-2023 06:04 PM
Hello,
I redeemed some points for extra data for 15 days. My regular plan that has 1 gb has been used up but I’m not able to use the data I redeemed with my points. What am I missing? Do you need to activate it?
Rewards
09-10-2023 02:20 PM
Yes correct!
09-09-2023 06:39 PM
09-09-2023 06:32 PM
Yup, that's what I said. 🙂
09-09-2023 06:26 PM
Thanks it seems I did add on the US data option. Thanks for all the help navigating!
09-08-2023 07:16 PM
I find it easier just to click the little spinners. But going all out with private mode does things too.
09-08-2023 06:55 PM
Interesting. Thanks for the tips.
09-08-2023 06:54 PM
@Mya2 wrote:Hello,
There is no extra data addons whilst in Canada for 15 days @Mya2 . Data addons, while you are in CANADA, last for 30 days.
Also, i find it odd you cannot go private mode. Although I don't think this will make a difference in this case. So for your records, try Open Safari on your iPhone. Tap the Tabs button . Tap [number] Tabs or Start Page to show the Tab Groups list. Tap Private , then tap Done.
09-08-2023 06:50 PM
Click on any of the little spinner refresh icons that you see then.
Canadian data add-on day counters are ##/30 (or more if more than one bought). US Roaming add-on day counters are ##/15. You have roaming. Maybe you could provide some images of your payment history from here showing what you see and also your list of add-ons. Don't show any personal info.
09-08-2023 06:42 PM
It doesn’t appear to be the roaming reward option. It doesn’t show that in my history. I’m not able to be incognito with safari as it’s an iPhone 8 which doesn’t have private mode.
09-08-2023 06:21 PM
Then that's the problem. You bought the roaming add-on. Are you in the states?
09-08-2023 06:20 PM
It shows there are 9/15 days left and 0% used
09-08-2023 06:10 PM
@Mya2 wrote:I submitted the request on Sept 2nd. And it shows in the history that it was spent.
HI @Mya2
submit a ticket with CS agnet:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Provincial-Taxes/m-p/1051292
And check My Account to see if the addon is there, remember use Incognito/Private/Secret mode on your browser
09-08-2023 06:10 PM
Oh, that's way too long for the alleged delay. Did you try the incognito mentioned above?
Do you see a day countdown in your add-ons? If so is it 15 or 30 days?
09-08-2023 06:08 PM
09-08-2023 06:06 PM
HI @Mya2
usually the redemption work immediately. Please use Incognito/Private/Secret mode on your browser to login My Account once again and see if you see the new data
if the data addon is there, reboot the phone. If not, then submit a ticket with CS agent:
09-08-2023 06:06 PM
I seem to think there's a delay between redeeming and it becoming available to use. How long ago did you redeem?
