Rewarded by the community
karlpasz
How do you know how much you will get in rewards and where do you look to start answering in the community?
How many replies does it take to get to $20?
jor123
I think the majority of people earn only $1-$2 however the last month I've gotten nothing even with community activity. Not sure how it works.
fdrcamb519
@karlpasz
I see it as people helping people, the rewards are a, bonus.
Staliger
@karlpasz Only Oracles, selected by PM, can get 20$. Other users - up to 15$. The formula of your reward is known only to PM. It is impossible for us to tell how active you should be, and how many posts/likes/etc you should have. Just add value to the community and help people😉
Just browse around and read lots of stuff. Then when a question pops up that doesn't have the right answer already, give it a reply and maybe others will give you a bravo for your efforts. Maybe the person asking the question will select your answer as the solution.
Then in the first week of a new month the rewards are calculated using a publicly unknown formula. Then if you've managed to earn some reward for the past month you will see an amount in your rewards area. Then at your next renewal, that amount will be added to your Available Funds to go towards paying for your plan cost.
Then it resets (each month...not renewal) and you do it all over again.
LovesToPM
Hi @karlpasz
Welcome to Public Mobile!
You're at the right place to answer questions. First off, do some reading to familiarize yourself with PM.
There's the English forum here:
https://productioncommunity.publicmobile.ca/t5/Public-Mobile-Community/ct-p/Public_Mobile_Community
and a French forum as well:
https://productioncommunity.publicmobile.ca/t5/Communaut%C3%A9-Public-Mobile/ct-p/Public_Mobile_Comm...
Start off slowly. You won't be able to earn the $20 reward right away. The $20 reward is reserved for Oracles (by PM invitation only). You can earn between $1 up to $15 monthly.
Good luck!
Sorry, but the maximum reward that you can earn unless being promoted to the rank of Oracle is $15.
There is no set amount of mesaages needed to be posted. Public Mobile will decide each month how much to total to pay to everyone and your participation will be compared to that of others.
