Resubmit transfer request
Meister
How do I get my transfer request resubmitted?
2 REPLIES 2
@Meister - refer @HALIMACS post if you are porting/transferring a number INTO public Mobile.
But, if you are transferring OUT of Public Mobile, your Public account should be active and you need to go to the new provider to get the request sent to the Public SIM card sent again.
HALIMACS
I'll send you a number you can call @Meister
To get it, tap your Avatar upper right to get to private message box. (or the little envelope which may be beside your Avatar.)
