Reset pin
laflix
Hi I can log into my account and need to upgrade my plan urgently plz. ********** email  alternate cell ********** or **********. Need reset pin to buy add ons. Andreset password to login. Tx 4 urhelp.
2 REPLIES 2
@lemew07, @laflix, both of you need to edit your posts, as no personal information is to be posted in the community forums.
lemew07
@laflix wrote:
Hi I can log into my account and need to upgrade my plan urgently plz. 438-877-8787 email [email protected] alternate cell 4383881844 or 4385218004. Need reset pin to buy add ons. Andreset password to login. Tx 4 urhelp.
Please Note you need to remove all your personal information from your original post. Hi you will have to private message a mod and provide PM number email address date of birth. I am missing what else you need to include but a quick search in the forms will give you what you need. wait time has been under a day latley so it is good. Good luck Lemew edit found this for you in the forms L https://productioncommunity.publicmobile.ca/t5/Self-Serve/How-do-I-reset-my-4-digit-account-pin/m-p/...
