Reset 4 digit pin
ZMakina
I forgot my pin so can't get help online . Please help me to reset it.
1 REPLY 1
will13am
@ZMakina , resetting your PIN code is a self serve function.  Go into your online account and under the profile tab you will see an option to update the PIN code.  Alternatively, use this link.
https://myaccount.publicmobile.ca/en/account/reset/pin
