Renewal
Oscar289
I would like to renew my subscription using a different Credit Card Number.  I am having problems with updating
the Credit Card Number on my file.  Please send me a step by step instructions on how to replace the Credit Card
Information.  Thank you...
@Oscar289
Login to your accounts on the PM app or website then to Payment tab-Update Card Information.
Oscar289
Thank you.... I will try that...
Chalupa_Batman
Hello @Oscar289
If you are having problems changing your credit card, it probably is a cache issue. Go into your browser settings, enter Cache into the search, clear cache, close browser, restart browser and go into incognito mode. This should work. OR, you can try updating it on the app. App works much better sometimes.
