Renew My Plan
Shellyr123
hello, I can’t figure out how to renew my plan.  I have a billing cycle from the 17th -> 17th, but I am out of data and would like to renew early,  changing my billing cycle to the 9th-> 9th.
How can I do this?  thanks
@Shellyr123 wrote:
thanks, this is good advice.  Are by chance moderator?  they are not responding to my messages
@Shellyr123 response time can be anywhere from a few hours to a couple of days -  although recent response times seem to be on the quicker side.
Pizzaeh
How much data does your current plan allow?  Changing to a plan with more data might be an option if you see yourself regularly using more data than your plan allows.
Shellyr123
@missorange  You can't actually renew your plan early, there's just an option to change plans immediately. Only moderators can renew a plan early.
missorange
you can purchase data add on.
NDesai
@Shellyr123  Your renewal date cannot be 17th to 17th as Public Mobile plans are based on 30 days and not monthly. You will see the correct renewal date if you login to your self-serve account
To renew early, you will need to send a private message to the Moderator_Team and they will get in touch with you shortly. Remeber that you will have to pay upfront for the new plan and you will not receive ay credit for unsued days of service.
