05-01-2021 11:10 AM - edited 01-06-2022 02:37 AM
I saw a post similar to mine. I need to have my number released because my employer has offered me a phone and I want to keep my number. I’ve tried and have failed several times. The bot wants me to sign in, I already have. It won’t accept my username or password
05-01-2021 12:46 PM - edited 05-01-2021 12:50 PM
@HALIMACS : Which still depends on ones email. I use Thunderbird as a client. The normal view of the email looks like:
It just shows Me and an email address.
Then when I look at headers I get (severely redacted):
From -
X-Account-Key: account3
X-UIDL:
X-Mozilla-Status:
X-Mozilla-Status2:
X-Mozilla-Keys:
X-Apparently-To:
Return-Path: <[email protected]>
Received-SPF: pass (domain of publicmobile.ca designates 208.38.59.78 as permitted sender)
X-YMailISG:
X-Originating-IP: [208.38.59.78]
Authentication-Results: from=publicmobile.ca; domainkeys=neutral (no sig); from=publicmobile.ca; dkim=neutral (no sig)
Received: from 127.0.0.1 (EHLO orkaan.nssi.telus.com) (208.38.59.78)
Message-Id: <@orkaan-i.nssi.telus.com>
X-IronPort-Anti-Spam-Filtered: true
X-IronPort-Anti-Spam-Result: =?us-ascii?q?
X-IronPort-AV: E=Sophos;i=""
Received: from unknown
MIME-Version: 1.0
To: "1000000#######" <kjhbsdflj@kjdnfgkj>
Date:
Subject: Your Public Mobile Activation Details
Content-Type: text/html; charset=utf-8
Content-Transfer-Encoding: base64
Content-Length: 13217
05-01-2021 12:26 PM
Of course, @Anonymous
Really only meant the wording of the subject line and how the account number displays (starting with the 1 then a whack of zeros before the sequential number) 😉
05-01-2021 11:46 AM
@Mearns : How the email looks depends on your email client or webmail and options therein.
05-01-2021 11:31 AM
@Anonymous wrote:@Mearns : That welcome email would also have your account number embedded in the To:. You might need to look in the headers.
You would also want to toggle autopay off if you can't log in to the self-serve by using the 611 service and your 4 digit PIN which you might find in your texts from "611" if you can't remember it.
If you can log in then remove your payment card there instead of 611.
Good point, @Anonymous
The activation e-mail header looks like this - if you can locate it in your e-mail account, you'll have found BOTH the account username e-mail address + the account number beginning with the "1000000 ......."
05-01-2021 11:23 AM
05-01-2021 11:20 AM
Thanks
05-01-2021 11:18 AM
As mentioned above, you will need to gain access to your self service account. You will need to provide the PM account number, account holder name and telephone number to be ported to Telus.
Here is some additional information:
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If you can't gain access to your self service account, you will need to contact moderator. If you are unable to submit ticket via Simon, you can directly private message moderator.
Send a private message to moderator through the following link :
05-01-2021 11:15 AM - edited 05-01-2021 11:16 AM
@Mearns wrote:I’m moving to Telus
When you activate with TELUS, they will ask for the Public Mobile account information to enable the port to occur from PM to TELUS.
Procedures are similar each way. After you complete the TELUS activation processes, you'll get a text on your PM service to "authorize" the port. Respond "YES" to the text, then your PM number will be moved to the TELUS service.
Here's an information article from TELUS:
Transfer phone number to new device or account | TELUS Support
05-01-2021 11:13 AM
Your account username is the e-mail address you initially activated with. If you can't recall which it was, check your most-used e-mail accounts for the "Welcome to Public Mobile" e-mail when you first activated.
Then, enter that e-mail into the username field, and from there, use the "Forgot Password" function.
05-01-2021 11:13 AM
I’m moving to Telus
05-01-2021 11:11 AM
Do you mean you want to move your existing Public Mobile account/number to another device, or another carrier?
Can you clarify, please?
