Registration issue for services
ThomasN
Hi,
I can't use my public mobile number to register for couple of services such as Google Play and Poparide. It says the number isn't valid.
What can I do?
@ThomasN wrote:
That's really frustrating - not anywhere, at Google nor at Public mobile I can get someone to take care of this ...
I think it's Public Mobile who needs to get something done asap
@ThomasN  sounds like an issue with your phone. What type of phone are you using?
ThomasN
ThomasN
Did everything I could
geopublic
@ThomasN wrote:
Hi,
What can I do?
@ThomasN Did you change your number? If yes, go into your Google account settingsand check your security settings.
cavemantoronto
@ThomasN wrote:
Hi,
What can I do?
How do they check if valid? I think if's a problem with those companies not accepting new area codes. Your Public Mobile phone works?
