08-14-2020 03:46 PM - edited 01-05-2022 12:47 PM
Hi there am using public mobile sim card from last one year it was really good experience with you guys but this time i have trouble to use my internet plan after rnewing my plan this month my cellular data not working as 4G internet anymore can you guys take a look that will be appreciate thanks?
08-14-2020 04:00 PM
@Sekhon5670 Did you restart your phone or your network settings? If you have the ability to check the sim in another phone, please do so.
08-14-2020 03:51 PM
@Sekhon5670 the data may not have provisioned correctly when renewing
you can contact customer support mods here
type "data troubleshooting"
(use the chat bubble options, then click "submit a ticket, click me" option)
https://publicmobile.ca.ada.support/chat/
make sure to check your inbox(top right corner envelope icon) periodically, for a response
08-14-2020 03:49 PM
@Sekhon5670 what do you mean cellular data is not working as 4G? Is data working at all? Sometimes depending on location, the connection can drop down to 3G.
