3 weeks ago
- last edited
3 weeks ago
computergeek541
Hi, l received a new sim card but it doesn't work in my phone or anyone else's phone so it obviously bad. So l had to go back with my old provider how do l get a refund from public mobile?
Thanks
3 weeks ago
Unfortunately l've already signed up with Virgin Mobile l just PM to port my number to Virgin. Thank you for the information
3 weeks ago
You don't need to go back to old carrier, just ask PM to provide you need one. Or if you already activated a PM account, could be just sim provisioning issue and not a bad sim
Work with PM for a solution. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
