Refund/Compensation?
11-22-2016 10:50 PM - edited 01-05-2022 12:50 AM
Will PM honour refunds of any form to frustrated customers who are leaving PM? I see on this forum that many people have been waiting for more than 2 weeks. I understand that employees are working hard to resolve everybody's issues, but customers should not have to pay for poor planning on PM's part.
Service
11-27-2016 08:12 PM
Anyone heard anything regarding compensation? I figure they're still backlogged...
11-23-2016 09:07 AM
I don't plan on leaving, but I hope that PM extends the renewal date to a month. For example, if you're next bill date is Feb 15, 2017 extend it to March 15, 2017. This is definitely something PM can do, and should do, and it will create goodwill.
11-22-2016 11:25 PM
lucky for you! my old SIM is no longer active!
11-22-2016 11:23 PM
11-22-2016 11:09 PM - edited 11-22-2016 11:19 PM
Wouldn't you rather have your billing cycle reset instead? After all, having lost 14 days as you have, isn't it much harder to use up what would then be a total of 16 GB in 76 days? That's like 6.4 GB per month.
Unless you're only experiencing problems with your number, but your data works. In that case, nvm. 🙂
11-22-2016 11:01 PM
Like others have said, it sounds like they'll modify the accounts in some way to compensate (if it comes down to that).
I'll gladly take an extra 4GB of data on my 90 days as compensation for the long wait
11-22-2016 10:56 PM
The most PM may do, Somethings with yer account, to perhaps make it right
11-22-2016 10:55 PM
Hi. PM is a Prepaid Carrier, Refunds are Ruled Out
11-22-2016 10:54 PM
Unfortunately, for prepaid plans, there are no refunds. Perhaps they will set your billing cycle to start from the day they fix your service. No guarantee, but doesn't hurt to ask.
