Referral code
Jasondimera
is there a way to get my referral code to give out without logging into my self serve?
8 REPLIES 8
AmberDawn
Once You know what it is, You could copy/paste or type it into a easy to access dig. Note on your phone for future reference n sharing!!
Bear2
  • No actually I'm not.  i just easily remember numbers
stevenanto
@Bear2 You must be giving it out constantly
Bear2
I just memorized my referral code.
HALIMACS
Hi @stevenanto
It'll be here:
Make sure if any 0 (zero)  or O (letter O) in it you know the difference if not using the link.
What you might want to do, is click on the link, then save the URL to then supply the URL others when they're ready to activate.  When they click on the URL, it'll take them directly to the activation screen with your referral code already pre-filled.
.... Or, simply write it down or screenshot it and provide it that way, works fine too if the person entering it pays attention if manually entering it.
stevenanto
I would login once and then save it in notepad on your phone
No, that's the only way.
No. Take a pic or screenshot.
