Referral code
MariaMath
Hi,
So when I signed up, I got excited and forgot to put in the referral code. Can I stillput in my friends' code?
Thanks!
popping
@MariaMath
Only moderator can access your account  As recommended by @hairbag1 to contact moderator.
After submitted a ticket, members should check their private message SENT folder for their ticket which they just created.
If you cannot find your ticket in your SENT box, You did not create your support ticket yet. Also monitor your INBOX for any reply from moderator.
Click the envelop icon at the top right corner to access your private message mailbox.
You can also enable email notification after you received a private message at your INBOX.
My settings --> PREFERENCES --> Private Messenger --> enable "Receive email notifications for new private messages' --> Save
MariaMath
Thank you! I will try this...
