07-01-2020 09:38 PM - edited 01-05-2022 11:56 AM
I used a referral code when I switched to public mobile. I am supposed to have a $10 1 time credit for using the referral. It does not show as a credit. How do I get this credit?
My Account
07-17-2021 09:21 PM
07-02-2020 01:04 AM
it takes time, if you still not getting it, ask the management team for help
07-01-2020 09:44 PM
Hello @jess4107,
The credit may be applied to the following months billing. Check for it. If not click on the bottom right hand corners check mark and submit a ticket to a moderator and they will look into your account and fix it.
Eliza5
07-01-2020 09:40 PM
This credit can take up to 72 hours to appear on your account. If it still doesn't show up after 72 hours, contact a Moderator.
