Refer Friend
Mikeyserbio
So it says on the site that you get $2OFF every month if u refer a friend. True or False..???
Michael77
@CalvinW,
True. 🙂
CalvinW
That would be great if it was true. But then, everyone would have free phone plans
Acekiller
Where do you see the $2 off?  Autopay is $2 off per month.
will13am
For each friend referred, the savings is $1 per month.  This is very clearly noted in the rewards webpage.
https://www.publicmobile.ca/en/on/rewards
