03-06-2019 06:36 PM - edited 01-05-2022 03:36 AM
I have a $1 referral reward in the Total Rewards earned area but not the image-based version of it. Obviously this isn't a major issue, if that $1 applies and is accurate. I just wanted to point out a potential bug (purple highlight below) with the portal. Is this occuring to anyone else?
Joining Public
03-07-2019 03:59 PM - edited 03-07-2019 04:02 PM
@slash407 wrote:im sure it'll get corrected, the webmasters would get on it
There isn't anything to fix as this isn't a bug on the website. The totals at the bottom are only accumulated rewards that have already been added to the account balance.
03-06-2019 06:57 PM
@awesomebynature wrote:I understand what that section means now. It's the cumulative rewards since joining. Each month I stay on auto-pay that will continue to go up by $2. The section above it shows what is actually going to apply to my balance.
Exactly. Enjoy you new service with Public Mobile.
03-06-2019 06:52 PM
03-06-2019 06:47 PM - edited 03-06-2019 06:55 PM
@Alex888 wrote:
Definitely looks like a bug, but it is showing up in your account so it should go through fine. If it doesn't send a message to a moderator to let them know.
It shows up in his account as he has 1 referral. But he hs not received his first $1 until after his next renewal date. He received the first autopay $2 right after activation. But he cannot refer any friend until after activation and will not receive any referral credit until after his first renewal day.
Edit: The title of this graphic is "total rewards earned since joining Public Mobile". He has not earned his first $1 referral credit until after his first renewal date.
03-06-2019 06:43 PM - edited 03-06-2019 06:45 PM
@awesomebynature wrote:I have a $1 referral reward in the Total Rewards earned area but not the image-based version of it. Obviously this isn't a major issue, if that $1 applies and is accurate. I just wanted to point out a potential bug (purple highlight below) with the portal. Is this .occuring to anyone else?
It's not a bug.
The list of rewards is showing what will be applied to your account at next renewal (based on today's parameters).
The " picture" shows what has been applied to your account up and including the last renewal.
03-06-2019 06:42 PM
03-06-2019 06:39 PM - edited 03-06-2019 06:54 PM
@awesomebynature wrote:I have a $1 referral reward in the Total Rewards earned area but not the image-based version of it. Obviously this isn't a major issue, if that $1 applies and is accurate. I just wanted to point out a potential bug (purple highlight below) with the portal. Is thisoccuringg to anyone else?
The highlighted graphic is the accumulated total referral credit you received since your account activation. Wait until after your first renewal. It will change to $1.
Note 1: The title of this graphic is "total rewards earned since joining Public Mobile". You have not earned your first $1 referral credit until after your first renewal date.
