04-29-2022 07:51 AM
I'm considering buying a new phone.
I'm looking at the Redmi Note 10 Pro Global.
As per frequencycheck.com, it supports the following:
GSM 850 1900PCS
UMTS B2(1900 PCS) B5(850)
LTE B4(1700/2100 AWS1)
Should I be good to go?
08-25-2022 08:39 AM
Thanks for reporting back and happen that it works well.
Cheers
08-25-2022 08:36 AM
Sorry for the late update.
My M2101K6R works perfectly with PM.
It's also been a great phone for me.
04-29-2022 11:41 AM
A good friend of mine has the Redmi Note 10 Pro as well and he is also on PM.
It will work fine with PM…you should be good to go.
04-29-2022 08:02 AM
Here are the bands that Redmi Note 10 Pro (Global) M2101K6G, M2101K6R has , the BOLD one are those compatible on PM
3G bands HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G bands 1, 2, 3, 4, 5, 7, 8, 20, 28, 32, 38, 40, 41
it looks good to me. But again, make sure yours is really Note 10 Pro Global M2101K6G, M2101K6R and NOT the the variants for Indian or Chinese Market, those 2 are completely different ones
04-29-2022 07:54 AM
Public Mobile uses the following frequency bands:
Looks good to go from what I can see:
And as per other posts, should be fine: https://productioncommunity.publicmobile.ca/t5/Get-Support/xiaomi-redmi-note-9-pro/m-p/685227
