Receiving calls
08-23-2019 04:26 PM - edited 01-05-2022 06:36 AM
Hi there,
I have recently change my phone from a flip phone (no data) to a smart phone (Razer android) and now it seems that i cant receive a call. We tried using my other phone to call but just 1 ring and it goes to voicemail. And in my phone just list a missed call but didnt actually ring.
Joining Public
08-24-2019 12:38 AM
@Anoden99 wrote:Hi there,
Check if you have some contacts accidtently blocked. Also check it unknown numbers are blocked in settings.
08-23-2019 05:47 PM
Are you on the $10 plan?
If yes, check your usage on your overview page.
The following line is on my account. I used 3 minutes out of 50.
Limited Canada-Wide Talk | 3 / 50 MIN |
If you don't see similar line on your overview page, you have used all your minutes.
You can buy minutes add-on if you run out of minutes.
08-23-2019 04:30 PM
@Anoden99Also make sure that the phone is not in Airplane Mode.
08-23-2019 04:28 PM
@Anoden99 hi do you have do not disturb on in your settings or something similar?
