Receiving/Picking new #
a400ryan
When I sign up a third phone in the family, along with its new #, do I get any multi choice of numbers ?
Like “ pick one of these five numbers for your new phone number “
cavemantoronto
@a400ryan
For the last 4 digits is only if you search during activation but not if you change number later.
hairbag1
@a400ryan...make sure to use a referral code from one of the existing accounts for the new account to take advantage of "Refer a Friend"... $1/30 days for each friend you refer – plus, your new account receives a one-time credit of $10.
Good deal, eh.
popping
Yes, you can.  IIRC, there is a choice to get additional 5 choices until you find a number to like.
LovesToPM
Yes you do.
More info here: https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
"With a new phone number, you’ll have to choose your city and province to get an area code. You can also select the option to customize the last 4 digits of your number. Note that you can change your phone number once every 30 days after you’ve activated."
