Real time data usage
dongbigd
Yo how about you guys update the data usage numbers so I can see how much I'm using instead it being for like a week then I check and I'm over my data limit. I still can't see how much data I'm using. It's stuck on the same number.
edited by computergeek541: removed inappropriate content
CS_Agent
Customer Support Agent
XX
Hi @dongbigd were you getting the number from the main page of My Account or from Usage History?  Usage History is generally 12 hours delay, but the number in the front oage is always up to date .  Try clear cache or use Incognito mode
Timer
@dongbigd
use other browser and clear cache and cookies and use one page inPrivate mode,
Login Page
and check it out the data usage,
