04-23-2026 12:12 AM
Hi can your help me ..
Hi How can I reactivate my esim after return the trip from Vietnam.
Thank you
04-23-2026 04:55 AM
How long were you away in Vietnam?
Was it longer than 90 days?
Did you pause your subscription while you were away?
04-23-2026 12:28 AM
Did you delete or disable the Public Mobile eSIM before you left? If you had deleted it, then you need to purchase a new eSIM from the app.
If you had just disabled it, then enable it again through settings and delete or disable any travel eSIM.
