Reactivate Solid Sim?
Rossa
Hey so I changed my solid Sim to an esim, and now I need to use this Sim for another phone but it doesn't connect to data. The Sim is recognized in the phone, however even after removing g the esim and disabling esim support on the other phone, the solid Sim still doesn't work.
Any way to restore the original solid Sim with the number? Or would I have to buy a new Sim card and transfer the number over?
I don't want to delete the esim but if that could work I will
slusagm
Just to add
Buy a new PM sim from Telus or Koodo or Mobile Klink ($10) or buy from Amazon ($5). And you probably better off to stay with physical sim
slusagm
After you change to esim, the old physical sim will not be useful anymore
  If you need physical sim now , you need to buy a new one and change to it.  But if you change to this new physical SIM card , the other eSIM would not be useful for anymore.  But if you need to change phones all the time,  you should stick with physical SIM card
hairbag1
@Rossa
the hard sim is finished now...you need a new one. They work 1 time only.
