Reached my data limit
mayushuo
Is there someone that can sort of help me move my payment schedulk up a bit. So i can pay for the next 3 months and get my data for those months?
It would save my life..thanks!
Acekiller
It has been done and confirmed by multiple members before so it is definitly your best option.
sbreakin
Yes a private message to Mod's & requesting an early renewal is the best option.
You can buy extra data add on but it is a bit expensive compared to regualr plans at $10 for 200mb & $30 for 1Gb.  ANd since you have used up plan data - seems that wouldn't last hat long.
links
Sending a message to the mod teams:
Contacting mods (details):
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-
Community-Mod.  How to send a private message:
https://productioncommunity.publicmobile.ca/t5/Getting-Started/Private-Messages-viewing-and-creating...
xCameron94x
you can private message the mods and you can re-new your plan early, but before you do that. You need to puts funds in your account equal to the cost of your plan
