08-18-2015 01:22 PM - edited 01-04-2022 01:54 PM
I noticed that Most of the SMS short codes will NOT work if you have CAN-Wide Txt ONLY
one needs Global Txt to use these
08-18-2015 01:39 PM
These are Canadian, as far as I believe. The TVO, Not sure
A PM client was mentioning about a Radio station SMS Short Code not working, Checked a few, strange
I will check more later on, and report my findings
08-18-2015 01:32 PM
1122-3
832-265
566-54
828-282
727-71
333-111
Those are ones I have tried within the last 15-20 mins
08-18-2015 01:24 PM
Hi @makkahn28 - Could you possibly provide us the specific examples for us to look into?
