7 hours ago
It looks like my SIM card is failing, which is causing the high data usage I had yesterday. How can I get a new SIM card?
please give me information anyone
2 hours ago
how high was the usage? can you provide us more background? was it usage from one specific app?
2 hours ago
Check your phone settings - just maybe you have active the "use data when wifi reception is poor".
2 hours ago - last edited 2 hours ago
HI @Jameslee12
don't get a new sim card yet, Sim card probably not not the cause to high usage. With SIM, it either connect to the network or not, it won't cause high usage.
Check the app on your phone first. Check which app used the data. if you are on iPhone, you need to reset data statistics and you can then monitor for couple days or weeks with the usage
if you really think something wrong with the system/account, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
3 hours ago
You can find them in convince stores like 7/11 or other shops near you. Best option is to Google a public Mobile sim (they use to sell theon Amazon, but I'm not sure if they do anymore) then you're able to link the new Sim to your old number and then you'd be good to go. Hope this helps
