11-30-2019 03:11 PM - edited 01-05-2022 08:13 AM
hi
just tried using sim in IPhone XR and says sim not supported here is my sim number
edited by comutergeek541: sim card number and personal contact information removed
11-30-2019 03:57 PM
@sharko1969 ive heard before that sometimes Rogers locks phones when you put a Sim in it. I'm not sure if you'd contact Rogers or freedom to get it unlocked
11-30-2019 03:50 PM
It's actually from freedom accepted Rogers sim but not public mobile
11-30-2019 03:46 PM
@sharko1969 wrote:How can I use a Rogers sim and it works
Does it work if you insert an active Bell or Freedom sim card?
11-30-2019 03:45 PM
@sharko1969 because it's locked to Rogers
11-30-2019 03:44 PM
11-30-2019 03:43 PM
@sharko1969 from that message it means it's locked
11-30-2019 03:41 PM
The phone us not locked to any other provider I have used other sim card also worked only public mobile sim has not worked
11-30-2019 03:17 PM
@sharko1969 the reason it says that is because the iPhone is locked to another provider other than telus/Koodo /public mobile
