Re: Problem with Provincial Talk Plan
fannycb
Hello,  I chane my plan yestertay to the provincial unlimited talk and I'm unable since then to make any call. I tried many number in the province. Can you help me please . The operator says it is not included in my plan. I tried restarting my phone but nothing.  thank you
10 REPLIES 10
srlawren
@Nasim97 would love to try to help.  what specific problem are you having with your provincial talk plan?
Nasim97
hello
need help , having  Problem with Provincial Talk Plan
srlawren
@Nasim97 did you have an issue you need help with?
Nasim97
@srlawren, I thought it was just the long distance warning too at first, but in this case I'm talking about, it truly was a message about talk not being active on my account.
i may have confused which phone call I was making, as I called various 519 numbers yesterday.  One of them had an extension added as x####, and as a result, wouldn't complete at all.  I didn't notice until inspected the number listed in the contact, and then edited the x, to the 'pause' function.  Once I fixed that, it dial properly.
Shazia_K
Retraité / Retired
Retraité / Retired
Thanks @srlawren
The issue has been resolved in a private message 🙂
Cheers,
Shazia
srlawren
@fannycb please try a combination of what @stonechucker and @Luddite have mentioned:  dial the phone number with a 1 in front of it, and completely ignore the message that long distance charges may apply--they won't. Just stay on the line and the call should connect.
Luddite
@fannycb Ignore any message about long distance charges; the call should go through. Also you can always ignore any messages suggesting extra fees. Public Moble is totally prepaid and NEVER has overage charges.
Acekiller
sounds like one of those unfortunate glitch.  One of the mods would be able to help.
@Mary_M can you assist?
stonechucker
I had this problem yesterday for the first time,  on my province wide plan also.
i had a number entered as (519)xxx-xxxx which is a long distance, provincial call, in a different area code.  I am in area code 226, which is geographically the same area of Ontario.  I had to put +1 in front of my desired call destination, for it to work.
