Re: Plan change did not change
robmue
I have the same problems, 3 months again on old plan, although the 30 days new plan was properly saved for renewal on Aug 8
1 REPLY 1
Kluna
Hi,
You need to send a message to Public Mobile, they will get back to you and will fix it for you. They were really quick to fix it for me when it happened.
K
