4 hours ago
I am having the same issue. I turned on my phone and it’s telling me I need a PUK code? What is that?
4 hours ago - last edited 4 hours ago
You must have accidentally put a PIN to lock your SIM.
You need to contact a CS_Agent to help you get the key.
4 hours ago
as said above, this is your situation
iPhone's status bar showing "Locked SIM"
open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
or use this direct link to open Chatbot ticket: https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened. CS Agent will reply to you there.
4 hours ago
Contact a CS_Agent to help you by clicking on the Chat bubble and type in Submit a Ticket or Contact Agent.
4 hours ago
oh and I have an iPhone
4 hours ago
This is the message:
4 hours ago
Help! I turned on my phone and am getting this message. What is happening?
4 hours ago
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier help unlocking it.
(Sorry, for this particular issue, PM support would not be able to help)
