Re: Number porting problem
tinowen2000
Hi
I ported my number from freedom mobile and I am not able to receive incoming call for over two days now but the outgoing calls work fine.
1 REPLY 1
Dunkman
@tinowen2000
@tinowen2000 wrote:
Hi
Looks like that your port form Freedom mobile is stuck.  Your original carrier likely sent you a confirmation port text.  Did you respond with a yes?
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
I will private message you the Telus porting number to call for additional help.  Check your inbox (envelope icon in upper corner of website)
