Re: No Service
Oll
Same here, no service since 2 days! Very frustrating. Central Alberta.
Oll
West of Millet. How do I change to 3G?
slusagm
which area you are at??
PM had system problem yesterday but got it fixed noem. But you can try changing network mode to 3G, should help for now
Oll
Existing costumer,  did all that and then submitted a ticket yesterday. I did not hear back and the service is most of the time off. I can not do or receive any calls,  messenging is verry spotty. Hubby and kids have the same problem. It seems to work in town but not out on the acreage.
hi @Oll ,
new customer or existing?? what have you don't so far??  Reboot the phone?? test sim in another phone? Reset all networks?? Tell us more
or you can open a ticket with PM support agent
please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
slusagm
no @Oll ,   This is a topic from years ago you have a different problem from everyone else
Maybe you need PM to help.  open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
