Re: How to Reach a Modulator
Hingchan
i made a mistake
please cancel 1000 US long distance minutes for 15$ and 200MB add on for 5$
thank you
@Hingchan wrote:
i made a mistake
thank you
@Hingchan
Community members do not have access to your account, nor are we Public Mobile representatives.
If you made purchases in error, try explaining to CSA and see if they can help you.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 -  Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Customer Support Agents (CSA)
ESS
Oh, Okay. Thx.
 @ESS : As often happens, newbies find a thread and post a question. You being the thread creator are "subscribed" to the topic by default and so you get a notification when someone posts in it. Calling a thread solved does not "close" the thread.
@Hingchan wrote:
i made a mistake
thank you
@Hingchan
you have to Contact Customer Support Agent by  ,
all in here community site they are same me and you customer no one can can help you...
ESS
Huh? What are you talking about? Are you sure you're replying to the correct topic?
