Re: How do I contact Public Mobile?
minadahesh13
Hello, I would like to open a new acct with public mobile since my old number was deactivated. I can no longer sign into my acct either... so not sure how to make it work? Please help! Thanks
12 REPLIES 12
@Blaise1975 wrote:
Bonjour
 @Moderator_Team < Click this.
Google Translate:
(cliquez dessus)
Que voulez-vous dire, vous ne pourriez pas parler avec votre cellulaire?
Blaise1975
Bonjour
srlawren
@wetcoaster another awesome response.  Well done.
@Khalidshaikh wrote:
Hi I want to switch to public mobile for Rogers.  Is there a possibility to do number portibility
@Khalidshaikh
Yes, you can port your number from Rogers.
We recommend that you set up an account with a temporary number and make sure that every service on your plan is working fine, incoming and outgoing. If you are happy with the service initiate your port with your account number (numbers only, no special caracters or spacing) and the name of the account holder of the Rogers account after checking the "I'm authorized" box.
Your phone needs to be unlocked and have the minimum of these frequencies https://productioncommunity.publicmobile.ca/t5/Discussions/LTE-network-fundamentals/m-p/198799/high...
Public Mobile doesn't support older, 2G GSM only phones.
You can check your phone's compability on willmyphonework.net.
Khalidshaikh
pakmode
@SD08 wrote:
@hjk
You've replied to a thread that is 5 months old.  I'm sure the OP's issue has long since been resolved one way or another.
In any case, Public Mobile changed its support structure after July 13, 2017 so that all help is now provided here through the PM community:
https://productioncommunity.publicmobile.ca/t5/Announcements/Changes-to-our-Support-structure/m-p/16...
Lol.
hjk
i'm sure they did:) ;and thnx for the extra info., i didnt know that!! just a day old in PM, heard they have some good customer service..running my tryouts 😉
SD08
@hjk
@hjk, this is the only place to contact customer service for Public Mobile.  They are no longer offering custoemr service through their Social Media accounts
hjk
Public Mobile also has its presence in different social media platforms.
Twitter Instagrtam Facebook with the handle @publicmobile
I'm sure you can contact them there as well. I think they have incredible customer service.
SD08
@minadahesh13
I see from this other post, your account expired in April: https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/Admin-please-reactivate-my-ac...
Any account that has been inactive for 90 days or more is removed. If it's been that long, that would be why you can't sign in to it. You would also have lost the phone number already.  To reactivate, you'd need to activate a new account with a fresh PM SIM card.  Moderator help is not needed in that case.
If it's been less than 90 days, then your account may need a password reset with the help of a moderator.
Click this Moderator_Team link to private message for assistance.
More info on moderators:  http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
Include your PM SIM card number, e-mail address and the phone number you last had with PM.  Also give them the details of any new plan you want if not simply renewing a previous plan.
NDesai
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
