Re: Data usage in the US
josiking10
same thing is happening to me right now! im mad
1 REPLY 1
HI @josiking10
most the time it is a device settings
1. which network you are on now? make sure you tried T-Mobile and AT&T , might need to manually select each of them to test
2. make sure roaming mobile data is enabled on the phone
3. change network mode to 4G or LTE
