Random Emergency number dialing
Abrahimhashimi1
So even since I start using public mobile many times my phone automatically calls the emergency number and then I have to explain to them that it was my phone problem, I did not call and I do not have emergency and have to give my information, I searched in my phone but could not find any option to turn it off. Please help.
Phone:
Asus Zenfone Max Pro (M1)
9 REPLIES 9
yanzhiqiang
@Abrahimhashimi1 wrote:
No man, the funny thing is when I have sim in other country I did not have this issue.
Have a look at this.
https://zentalk.asus.com/en/discussion/38082/off-emergency-call-press-in-power-button
Abrahimhashimi1
popping
@Abrahimhashimi1
Is there any app dial 911 triggered by a event on your phone?
Abrahimhashimi1
I have those enabled but still not working.
A speed dial set to 911 being engaged?
A button on the side set to an option of dialing 911?
My Samsung A31 has an SOS option.
Abrahimhashimi1
YES sir, it calls 911 randomly and I did factory reset but the result is the same.
popping
@Abrahimhashimi1
Are you saying that your phone dial 911 by itself?
Backup you phone and do a factory reset.  A fresh start may fix the issue.
mimmo
I assume you are calling 911.  i really can't see how its a Public mobile issue.
do you have a screenlock /pin enabled?     if not maybe that will help.  or a case with a cover?
