a month ago
Just got a new cellphone it says to scan the QR CODE where is the code I'm not good at technically l'm dumb Thank You
3 weeks ago
Thank You for the help
3 weeks ago
Yes Thank You you gave the best advice my daughter set it up l don't do much on my phone text,calls
a month ago
yes, esim will work
but for Samsung new phone, you need to borrow a sim card from a friend to setup the phone first. It is not something that Samsung needs it , not a problem with Public Mobile. So, get a physical sim from friend, setup the phone with Google and Samsung.
Then download Public Mobile ap on the new phone and login. Then go to Account -> Purchase Sim card and choose eSIM and buy and install
if your last eSIM was bought 15+ days ago, it should be free
a month ago
My new cellphone is Samsung Galaxy A17 5G will your sim card fit my phone if sol will order one Thank You
a month ago
do you need eSIM?
just download PM app on the new phone, login and go to Account -> Purchase sim card and buy eSIM
