Puk locked sim
Lazie
Hey had no service bars before I accidentally locked my sim card on self n now what do I do ugh huh I'm distracted.
11 REPLIES 11
Johnny_6969
Need the pin code to unlock
@Haydn04You need to contact the Moderators with this link here.. be expect to hear from them up to 48hours.
Haydn04
need puk code
ClaudeR
Above, I see that you've checked to indicate that you problem is solved now.
Should you have anything else, don't hesitate...
Lazie
Provide me with one"
ClaudeR
Yes, I know; but hasn't our friend here got one first any before?
A new client then...?
@ClaudeR wrote:
Does it mean that the PUK # we get with our SIM card doesn't work, after we used it once?
PUK is not included with the sim card. It is a secret code that only the moderators can provide.
ClaudeR
@ClaudeR wrote:
I would try this:
=== remove the SIM card, restart my phone, reinstall the SIM Card and see if you could enter the PUK # back again...
For that to.work, the customer would first need to have the sim card's PUK.  That can only be provided by moderators.
ClaudeR
I would try this:
Lieux
You need help from the moderator here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 they will help you. Waiting time is few hours to 2 days but they work 7/7 days.
