Puk code
Andrea20
My new device says I need a puk code. Can anyone help pls?
Andrea20
Thank you! Yes it worked in the old phone.. that I broke today lol I'll try bell aswell. Thank you
Andrea20
Thank you! Ticket sent
hi @Andrea20
what is the message about the PUK? it could be a carrier lock code it is looking for since you are using a new phone
but if it is just a PM sim card PUK, then support can help.  You will need to  submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
slusagm
if the PM sim card still works on the old phone, then the new phone is carrier locked.  You need to call the provider which the phone was from originally and ask for an unlock code
