08-06-2019 02:24 PM - edited 01-05-2022 06:17 AM
does anyone else have their phone "auto clean" followed by advertising?
quite often after closing an applicaiton, my phone says Public Mobile has cleaned up my storage, then it proceeds with an advertisement.
any help would be appreciated. thanks
Phones
08-06-2019 05:11 PM
@JaxonMolly wrote:does anyone else have their phone "auto clean" followed by advertising?
I don't think anything has been cleaned. I see this as just advertising by someone, and it has nothing to do with Public Mobile. I remember a while back, I ended up uninstalling ES File Explorer because of random full screen ads. Network Signal Info tends to play full screen videos when exiting.
08-06-2019 03:01 PM - edited 08-06-2019 03:02 PM
Sounds like an infected phone to me. I despise the word cleaner or any app that shills this service. I would rather keep a "dirty phone". Quite often the AV type apps are worse than malware.
08-06-2019 02:53 PM
@JaxonMolly I would be very worried if I were you and remove the responsible app. You should download a legit av cleaner for your device and run it asap.
08-06-2019 02:45 PM
That's not Public Mobile doing that. One or more of your apps are and they have permissions that might not be appropriate.
08-06-2019 02:44 PM
I have never heard of this with PM. Are you getting pop ups ads ?
